foodpig1
Apr 27, 2022Aspirant
Fios Triple Play (Phone)
Hi,
Doing a setup for my parents. Personally I have an Orbi in AP mode with my fios Router in Bridge mode. My Orbi powers my wifi and I have no problem with wireless mini boxes and cable. My parents want to the do the same setup, but they have a VoIP with Fios. Will VOIP with Fios work?
Sort By
foodpig1 wrote:
Hi,
Doing a setup for my parents. Personally I have an Orbi in AP mode with my fios Router in Bridge mode. <IF the FIOS router is in bridge mode, then your Orbi should be in Router mode, not AP mode. My Orbi powers my wifi and I have no problem with wireless mini boxes and cable. My parents want to the do the same setup, but they have a VoIP with Fios. Will VOIP with Fios work? Does the parents ISP modem/ONT have a built in router too? If so, Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- foodpig1Aspirant
Thanks I meant, turning the wifi signal off on the Verizon router and not bridge mode.
Should work, just need to see what kind of ISP modem configuration they have.
