madotom
Jan 10, 2021Aspirant
firm ware update Rbr 20
I know there is a firmware update but when i go to check for update it gives me a message that everything is up to date. When are firmware updates available for automatic update?
Jan 10, 2021Guru - Experienced User
NG seems to take there time in putting new FW up on there auto update servers. You can manually download and manually apply FW using a wired PC and web browser using NGs support site as well:
https://www.netgear.com/support/product/RBK20.aspx#download
Good Luck.
madotom wrote:I know there is a firmware update but when i go to check for update it gives me a message that everything is up to date. When are firmware updates available for automatic update?
- FURRYe38Jan 10, 2021Guru - Experienced User
- madotomJan 10, 2021AspirantFinally got a manual update completed. Thanks for your help. Not an expert but why did you specify a wired connection?
Wireless connections can be problematic when doing FW updates. Having a hard wire connection to the RBR helps maintain better connections when doing a manual FW update. Safer that way. Glad you got it working. Be sure to save off a backup configuration to file for safe keeping. Helps save time if a reset is needed.
Enjoy. :smileywink:
- madotomJan 10, 2021AspirantWired- you’re talk about a wired connection from my modem to my laptop correct? I’m a dummy when I’d comes to these things. I know enough to get my self in trouble😬
