Desmond_Lau
Jul 16, 2017Star
Firmware 1.12.0.18 turn off wireless by schedule setting disappear
Hi, everyone. Anyone can help to check this function for me. I don't know my Orbi got problem or this new version firmware removed.
quentin
Jul 17, 2017Aspirant
The scheduling function does not disappear
Just set the way to change
Is currently in stable use
you try it!
- Desmond_LauJul 17, 2017Star
Where can you find the way? Can you tell me more details? I can't find the way to set the schedule.
- superben79Jul 17, 2017Apprentice
"Just set the way to change
Is currently in stable use"
what does it even mean?
- quentinJul 17, 2017Aspirant
I set the way
You can try!Is this the way you want to set it?
Oh Quentin, this is not I want. I want to turn off wireless signal instead of block service... Anyway, thank you for your reply. @.@
