Skrymir
Nov 10, 2016Guide
Firmware 1.3.0.26
The release notes included the zips are just install instructions. Anyone have real release notes for .26?
PhoenixV
Nov 11, 2016Apprentice
Seems like the Attached Devices screen now includes the Sattelite screen. The option to toggle the display is removed from the debug screen
- loomis1975Nov 12, 2016Luminary
When I updated to this firmware, the router wouldn't talk to the cable modem at all. I had to master reset the router, and reload the settings, then all worked again.
- PhoenixVNov 12, 2016Apprentice
Well it looks like I spoke too soon. In the version 1.3.0.12 the option to turn on display of the satellite was found in the debug screen. This option was turned on when I did the update to the current version. After the update, the advance screen showing connections to the router and to the satellite continue to be displayed. However I was forced to do a reset of the entire system due to another situation. After the reset of the system and the subsequent normal set up a routine, the display of the wireless connections to the router and to the satellite are now gone, and have been replaced by one consolidated display. The option to enable the advanced view is no longer available in the debug screen. Does anyone know how to get it back?
Same thing happened to me.
I guess you could try downgrading the firmware one revision, then master reseting the router and see what you get.
I have never had to master reset the satellite, just the router. But then again, I haven't had to downgrade the firmware on the satellite either.
- dsc_dewainNov 12, 2016Guide
This is how you can get to the satelite status page: http://192.168.1.4/status.htm just be sure the ip address is of the satelite( you can try .2,.3,.4 etc
If you get there, it will prompt you for the admin password.
- peteytestingNov 12, 2016Hero
its not a matter of trying , just go to the orbi web page and it will show you the ip address of the sat / sats
