Skrymir
Nov 10, 2016Guide
Firmware 1.3.0.26
The release notes included the zips are just install instructions. Anyone have real release notes for .26?
XBond
Nov 13, 2016Apprentice
Strange, mine doesn't show that after the update.
PhoenixV
It seems that if you have the option enabled prior to doing the update to the latest version of the firmware, it continues to display after the update as well. However if you reset the router, the display will default back to the "normal" display of attached devices, and there will be no way to enable it again. Also if you have a new installation and are setting up Orbi for the for the first time, updating the firmware as part of the process, there will be no way to enable that particular screen. If there is someway to enable the screen once again, I have not been able to find it because the toggle has been removed from the debug screen.
I have already notified Netgear technical support, and they are escalating the question/suggestion to enable the function once again in a future version of the firmware.
