Skrymir
Nov 10, 2016Guide
Firmware 1.3.0.26
The release notes included the zips are just install instructions. Anyone have real release notes for .26?
XBond
Nov 19, 2016Apprentice
Actually, just connected to www.orbilogin.com and the router doesn't see the satellite. What the heck??? Satellite is turned on. In the same location.
Something is clearly wrong. Used to work flawlessly before the fw update.
JMU1998
Nov 19, 2016Luminary
I see the same issue a reboot fixes it for me but the issue returns in 2 or 3 days then another reboot will temporary fix it...
- DarrenMNov 21, 2016Sr. NETGEAR Moderator
Hello Xbond
You could try to factory reset the router see if that corrects the issue or you could try to load the old firmware which you can get on the orbi support page and see if its the new firmware causing the issue.
DarrenM
