Skrymir
Nov 10, 2016Guide
Firmware 1.3.0.26
The release notes included the zips are just install instructions. Anyone have real release notes for .26?
JMU1998
Nov 20, 2016Luminary
I see the same issue a reboot fixes it for me but the issue returns in 2 or 3 days then another reboot will temporary fix it...
DarrenM
Nov 21, 2016Sr. NETGEAR Moderator
Hello Xbond
You could try to factory reset the router see if that corrects the issue or you could try to load the old firmware which you can get on the orbi support page and see if its the new firmware causing the issue.
DarrenM
