Skrymir
Nov 10, 2016Guide
Firmware 1.3.0.26
The release notes included the zips are just install instructions. Anyone have real release notes for .26?
GamerHonu
Nov 22, 2016Star
Bought an Orbi last night after a recommendation from a network salesman at BestBuy. He was knowledgable based on his answers to my questions and I trusted that he'd help fix our long running latency issues. The Orbi and his recommendation did not disappoint. Just after 12 hours of usage I'm completely sold on this device. So direct to the point... It's running the default initial firmware. It's working great. Should I update to the latest version or any version in between?
"Don't fix what isn't broke." is something I try to live by when it comes to tech; updated enough other routers in my day that I regreted later.
DarrenM
Nov 22, 2016Sr. NETGEAR Moderator
Hello GamerHonu
It is suggested to update but if you run into a problem you can manually revert back to a old firmware which is listed on the support page for orbi.
DarrenM
- GamerHonuNov 23, 2016Star
Unforunately Orbi updated the main router itself overnight to 1.3.0.26. Found out because I woke up to no internet and an Orbi satellite on 1.1.0.16. Had to connect to LTE via my phone in order to download the satellite firmware and updated it manually. After a complete power cycle of my cable modem, I have internet. Anyway to stop Orbi from doing this again?
I'm noticing that the Orbi satellite is reporting no connection on the 2.4ghz band since updating the firmware to 1.3.0.26. Any ideas as to why? The Orbi satellite itself has no lights on reporting any errors but inside the status page it shows "2.4GHZ No Connection".
- JMU1998Nov 23, 2016Luminary
I have noticed the same, I am hoping it is a bug that the upcoming fw will address
