Skrymir
Nov 10, 2016Guide
Firmware 1.3.0.26
The release notes included the zips are just install instructions. Anyone have real release notes for .26?
DarrenM
Nov 22, 2016Sr. NETGEAR Moderator
Hello GamerHonu
It is suggested to update but if you run into a problem you can manually revert back to a old firmware which is listed on the support page for orbi.
DarrenM
GamerHonu
Nov 23, 2016Star
Unforunately Orbi updated the main router itself overnight to 1.3.0.26. Found out because I woke up to no internet and an Orbi satellite on 1.1.0.16. Had to connect to LTE via my phone in order to download the satellite firmware and updated it manually. After a complete power cycle of my cable modem, I have internet. Anyway to stop Orbi from doing this again?
- GamerHonuNov 23, 2016Star
I'm noticing that the Orbi satellite is reporting no connection on the 2.4ghz band since updating the firmware to 1.3.0.26. Any ideas as to why? The Orbi satellite itself has no lights on reporting any errors but inside the status page it shows "2.4GHZ No Connection".
