LHZ
Oct 25, 2017Guide
Firmware 2.0.0.74 incredibly unstable
My Orbi system is practically unusable currently with v2.0.0.74 and 2 satellites. I cant watch an evening of streaming TV without the sateliitle disconnecting and becoming unusable. I have tried to d...
DonM
Oct 26, 2017Aspirant
I had some issues with stability, but it was because one of my satalites was not the latest firmware and the rest of the devices were. Once I fixed that I've been rock solid. I was hesitant to purchase because of all the stability complaints, but I guess I've lucked out.
- DarrellRiffeOct 26, 2017Apprentice
I finally gave up on the Orbi and went with the EERO system, which (fingers crossed) works great and hopefully will continue to do so. When the latest (2.0.0.74) software was released (after installing the EERO), I hooked up the Orbi to my EERO and through ethernet, upgrade the main and satellites to the new firmware. From what I can tell, all seems to be working on the Orbi end. But, I have not spent the time to hook up the Orbi as the main router and test it as a system. I'm just trying to ensure that a stable system exists before handing it off to a friend - I don't want to pass on a system that won't work reliably. The EERO is definitely working very well as a true mesh system, whereas the Orbi wasn't handling anything when I ditched it. That said, it is possible that Netgear has fixed things - I'm just not sure, as I've not had the opportunity to fully test it.
