migsta
May 22, 2018Apprentice
Firmware 2.1.4.10
OMG, I decided to revisit Orbi for a 2nd time after trying out Aimesh and Velop. All I can say it's extremely broken in comparison to using it a few months ago. The setup process is buggy/messy and...
tsig
May 23, 2018Luminary
Glad I have none of those issues. Mine is screaming fast and has been rock solid from day one, including automatic, seamless firmware upgrades.
migsta
May 23, 2018Apprentice
If your reply is correct, you show that your have a "wireless backhaul" where I'm trying to achieve a wired backhaul that simply crashes the system. Therefore, I believe you do have the issue if you try and place your satellites in a wired backhaul config. And, you have 2 RBR50's in AP mode - seems odd unless you're running two totally seperate configs?
- tsigMay 23, 2018Luminary
Thanks for pointing out my incorrect signature I corrected it. I maintain I do not have any of your issues and will not be finding out about the wired backhaul. My wireless backhaul provides more speed than I can use.
