22rich22
Jul 08, 2018Tutor
Firmware 2.1.4.16 Troubles / Issues
Ever since my system upgraded to Firmware 2.1.4.16 last week, the Orbi router occasionally and without notice reboots (static magenta). Just tonight it did it twice over a 3 hour period. My system ...
- Jul 09, 2018
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
Jul 09, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
- 22rich22Jul 09, 2018Tutor
I don't have a modem combo unit. The modem is through Xfinity and it's a Cisco XB3. I have an Orbi router and a separate Orbi satellite.
- FURRYe38Jul 09, 2018Guru - Experienced User
Is this the modem you have?
Yes, I believe it is (I'm not home right now). I think what you're getting at is that the Xfinity modem also acts as a router and its signals may be conflicting with my Orbi router signals. When I had the modem installed I made sure to have Xfinity turn off the router function so that it would only function as a modem, but it's possible that it got turned back on with an update. Nothing would surprise me with Comcast! I'll have to check when I get home.
