cjaubert
Oct 05, 2018Aspirant
Firmware 2.1.4.16 Troubles / Issues
Where is the Macintosh or Apple version of the 2.1.4.14 firmware downgrade? I can only find the Windows version. Thanks.
Oct 05, 2018Guru - Experienced User
FW is not OS specific. Only Orbi model specific.
cjaubert
Oct 07, 2018Aspirant
Thanks. My question, though, relates to the img file format. The Mac OS doesn't/can't open it, and I can't convert it, so I can't install it.
- FURRYe38Oct 08, 2018Guru - Experienced User
You don't need to unpack the IMG file either. Just open a web page in Safari or FF browser and navigate to the routers web page and navigate to where the FW update UI is. Use the UI then to select the IMG file from the desktop. Select this file, then let the router and satellite handle the file loading from there.
