steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Oct 03, 2018Guru - Experienced User
Let us know if you experience any issues after updating FW.
Let us know if you apply the new FW and continue or if you factory reset the system and set up from scratch. Hopefully you can just update and continue, however if you seem to experience issue. Please try a factory reset if needed.
RedBatman89
Oct 03, 2018Guide
I have an issue. When this update happened it took longer for my sattelties to reconnect and when they did it first went to maggenta for a minute before blue. Also there is a bug or something but Now for 5ghz decives it will list the connection as unknown and connected to sattelite. Not really specfying. For wired and 2.4ghz its fine.
I think there is a bug in the new firmware. Even after I had to do a factory reset it still shows.
Please let me know if anyone else is getting this. My internet works but this is starting to make me irratated
- BenniePOct 04, 2018AspirantI have been having several issues with my devices (ring cameras, dell laptop, slow internet) and just found out the Orbi system updated before problems began. Please fix this soon!!
- FURRYe38Oct 04, 2018Guru - Experienced User
Try a factory reset on the Orbi system and set it up from scratch if the system was updated.
