steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Oct 03, 2018Guru - Experienced User
Sounds like a factory reset and setup from scratch is needed after the system is updated to v210...
I would recommend to everyone factory reset the system after a FW update and set up from scratch. At least try this before attemping to revert back to prior FW or posting about it.
- jblack68Oct 03, 2018Apprentice
Yeah same bug happens to me, all 5GHZ connected to Satielle will show as Unknown even after a factory reset on both Router and Satellite
- FURRYe38Oct 03, 2018Guru - Experienced User
Is the system working?
What browser are you using? Try IE11, FF or Opera?
- jblack68Oct 03, 2018ApprenticeThe system working fine and also the Orbi app shows glitched names and also shows unknown for the 5ghz. Tried safari and chrome and mobile as well.
Issue with the firmware.
