steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Oct 03, 2018Guru - Experienced User
Is the system working?
What browser are you using? Try IE11, FF or Opera?
jblack68 wrote:
Yeah same bug happens to me, all 5GHZ connected to Satielle will show as Unknown even after a factory reset on both Router and Satellite
jblack68
The system working fine and also the Orbi app shows glitched names and also shows unknown for the 5ghz. Tried safari and chrome and mobile as well.
Issue with the firmware.
- Retired_MemberOct 03, 2018
Issue with the firmware.What you're describing may be a problem with the app not the FW. How is your internet connection in real time as in not looking at the app. Can you visit a website? Not sure what glitched names are, but if you can get to the Internet, try not worry about the rest.
- jblack68Oct 03, 2018ApprenticeIt’s defo the firmware, the issue is that it shows unknown for the 5ghz connected to the satielle.
Internet and that seems fine.
- FURRYe38Oct 03, 2018Guru - Experienced User
Might give it some time to settle is and see if the names return and the connection status reports correct.
Besure that your devices have unique names in the Host Name sections...
Issue with the firmware.- Christian_WOct 03, 2018Star
I did run the update through the app and after reebot everythig just went bad.
I had to do a factory reset on the system and now after atleast 2h with sync issues i am back up and running again.
- RedBatman89Oct 03, 2018Guide
Still listing as unknown.
