steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Oct 03, 2018Guru - Experienced User
Might give it some time to settle is and see if the names return and the connection status reports correct.
Besure that your devices have unique names in the Host Name sections...
jblack68 wrote:
The system working fine and also the Orbi app shows glitched names and also shows unknown for the 5ghz. Tried safari and chrome and mobile as well.
Issue with the firmware.
Christian_W
Oct 03, 2018Star
I did run the update through the app and after reebot everythig just went bad.
I had to do a factory reset on the system and now after atleast 2h with sync issues i am back up and running again.
