steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Oct 03, 2018Guru - Experienced User
Try a factory reset on the system and setup from scratch?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
DaytonaZ33 wrote:
Did anything change regarding the status of the satellite backhaul? Previously I had always "Good" status, now after this update my status is stuck at "Poor" even after reboot. No furniture or anything in the house has been moved in months, now all of a sudden this is an issue.
Bullyterrier
Oct 03, 2018Star
Hmmm, mine have updated and now are wide open....192.168.1.1 requires no login, nowhere to set admin password - if i logout I'm still logged in. Will try factory reset in the morning to avoid alienating the family again tonight.
- FURRYe38Oct 03, 2018Guru - Experienced User
Did you look under Advanced Tab/Advanced settings/Admin?
- BullyterrierOct 03, 2018StarYes of course Furry. The option re admin is simply missing.
- RocketSquirrelOct 03, 2018Luminary
I see password setting under Advanced > Administration > Set password using firmware V2.2.1.210. If that's missing on yours, maybe re-flash. I did not factory reset after updating firmware today and found no need to.
