steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Ryan1919
Oct 03, 2018Tutor
Mine is wide open as well and I didnt update my firmware yet. When I logout and then login again on the web interface it logs right back in without asking for a password. Is this suppose to happen? Does it know my ip address and allow me into the site without the password or is this a bug? It seems like it should ask me for a password. It use to ask me everytime but now it doesnt.
Bullyterrier
Oct 04, 2018Star
So, re my 40 having no admin security.
Factory reset brought back the password option but left the wireless admin page non responsive.
Manual download of the img files and manual update plus factory reset has resolved both.
So, flakey update issues remain.
Check your updated hardware carefully!
- FURRYe38Oct 04, 2018Guru - Experienced User
Seems like this maybe a good process to update FW. Thanks for letting us know.
Enjoy. :smileywink:
Check your updated hardware carefully! - cool2562Oct 05, 2018StarI manually updated my satellites first then the router. How do I reset to factory defaults?
- FURRYe38Oct 05, 2018Guru - Experienced User
You can use the web pages for the satellites and router or use the pin hole button on each unit. Press in the pin hole button until the top led turns on AMBER, then let go.
You can find the ERASE feature under Advanced Tab/Advanced/BackupSettings in the ui.
