steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
RedBatman89
Oct 03, 2018Guide
I have an issue. When this update happened it took longer for my sattelties to reconnect and when they did it first went to maggenta for a minute before blue. Also there is a bug or something but Now for 5ghz decives it will list the connection as unknown and connected to sattelite. Not really specfying. For wired and 2.4ghz its fine.
I think there is a bug in the new firmware. Even after I had to do a factory reset it still shows.
Please let me know if anyone else is getting this. My internet works but this is starting to make me irratated
BennieP
Oct 04, 2018Aspirant
I have been having several issues with my devices (ring cameras, dell laptop, slow internet) and just found out the Orbi system updated before problems began. Please fix this soon!!
- FURRYe38Oct 04, 2018Guru - Experienced User
Try a factory reset on the Orbi system and set it up from scratch if the system was updated.
