steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
tkshaffer
Oct 05, 2018Guide
Updated through the app...both router and satellite came right back up and everything seems to be running smoothly.
Oct 05, 2018Guru - Experienced User
Sounds like you got lucky. Glad yours is working well. Enjoy.
- soundersfcOct 05, 2018Apprentice
Just adding one data point here of mine that the update is working great for me. I updated through the web browser not the app.
I have a RBR50 and an RBS50 and both upgraded fine and kept my SSIDs separate which I need for the Orbi to work at my home.
Same throughput and everything so far, woohoo!
- FURRYe38Oct 05, 2018Guru - Experienced User
- Retired_MemberOct 05, 2018
The way we use the word 'lucky' makes it sounds with the FW updates, unless you have luck on your side you're destined to fail.
