steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
esassaman
Oct 06, 2018Tutor
For those of you completely scared out of your wits as I was after reading all the previous posts, sometimes it just works.
I did the update just now. It was surprisingly fast, only took a few minutes. It took a few additional minutes for the sattelite to reconnect (wired backhaul). All settings are exactly the same as before the update. All attached devices are there with the same names. Sattelite is good, got a solid ethernet connection. No resets, no reboots, nothing needed. Whew.
- Andy555Oct 06, 2018Aspirant
same for me. installed itself overnight-no issues at all in the morning. everything showing up as it should on sat and router. Router in router mode (not AP), and I'm not running ethernet backhaul.
- tdroz73Oct 06, 2018Tutor
This update is hell. The previous version was nice and stable - why are we defaulted to auto-update?
Mine auto-updated in the middle of the night - woke up to intermittent internet. Rebooted the router and it came back up - at 1/10th the normal speeds! I have a gigabit connection and was getting 100mbps on WIRED connections - 40-60mpbs on Wifi.
I powered down the satelite and then restarted the router and rebooted the cable modem. And waited what seemed like 5+ minutes. Router now gives me gigabit speeds and regular wifi speeds 400-600mbps.
Haven't turned on the satelite yet...
I'm about ready to look for an alternative product. I will no longer recommend this product to anyone who asks.
No factory reset because that's total BS. I think that is purely coincidental that it corrects anything - likely because there's old settings in the config that don't get properly migrated during the update process. When you go through this process and factory reset - all you're doing is hiding bugs from Netgear. Make them find them and fix them!
Netgear - stop pushing beta software like this out. I understand its a complex beast - but doing a factory reset to install clean software means you have **bleep**ty software engineering practices. You can't both expect us to accept auto-updates AND require us to manually intervene for 30 minutes to factory reset or power refresh everything.
- cool2562Oct 06, 2018StarMy WiFi speeds are much slower now. My SkyBell doesn’t even work anymore. I will not recommend this product to anyone. At least give us the optiion or keeping the old firmware if the new one is giving us issues.
- Cmax04Oct 06, 2018Aspirant
Same here.
- Ryan1919Oct 07, 2018TutorCan you confirm that your 5g connected devices to a satellite are showing their connection type in the web interface and app. For example all my devices that are connected to 5g say unknown for the connection type in the web interface and mobile app.
- BodiniOct 07, 2018Aspirant
Confirmed - RBR50 / RBS50 - Both devices show correct information for 2.4G and 5G. Wired backhaul and upgrade completed with no issues.
