steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Andy555
Oct 06, 2018Aspirant
same for me. installed itself overnight-no issues at all in the morning. everything showing up as it should on sat and router. Router in router mode (not AP), and I'm not running ethernet backhaul.
tdroz73
Oct 06, 2018Tutor
This update is hell. The previous version was nice and stable - why are we defaulted to auto-update?
Mine auto-updated in the middle of the night - woke up to intermittent internet. Rebooted the router and it came back up - at 1/10th the normal speeds! I have a gigabit connection and was getting 100mbps on WIRED connections - 40-60mpbs on Wifi.
I powered down the satelite and then restarted the router and rebooted the cable modem. And waited what seemed like 5+ minutes. Router now gives me gigabit speeds and regular wifi speeds 400-600mbps.
Haven't turned on the satelite yet...
I'm about ready to look for an alternative product. I will no longer recommend this product to anyone who asks.
No factory reset because that's total BS. I think that is purely coincidental that it corrects anything - likely because there's old settings in the config that don't get properly migrated during the update process. When you go through this process and factory reset - all you're doing is hiding bugs from Netgear. Make them find them and fix them!
Netgear - stop pushing beta software like this out. I understand its a complex beast - but doing a factory reset to install clean software means you have **bleep**ty software engineering practices. You can't both expect us to accept auto-updates AND require us to manually intervene for 30 minutes to factory reset or power refresh everything.
