steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
esassaman
Oct 05, 2018Tutor
For those of you completely scared out of your wits as I was after reading all the previous posts, sometimes it just works.
I did the update just now. It was surprisingly fast, only took a few minutes. It took a few additional minutes for the sattelite to reconnect (wired backhaul). All settings are exactly the same as before the update. All attached devices are there with the same names. Sattelite is good, got a solid ethernet connection. No resets, no reboots, nothing needed. Whew.
Cmax04
Oct 06, 2018Aspirant
Same here.
- Ryan1919Oct 06, 2018TutorCan you confirm that your 5g connected devices to a satellite are showing their connection type in the web interface and app. For example all my devices that are connected to 5g say unknown for the connection type in the web interface and mobile app.
- BodiniOct 06, 2018Aspirant
Confirmed - RBR50 / RBS50 - Both devices show correct information for 2.4G and 5G. Wired backhaul and upgrade completed with no issues.
- Ryan1919Oct 06, 2018TutorOk thanks!! I think the main difference between our setups is yours is wired backhual. My 5g connections show as unknown and it will just say Orbi Satellite instead of the custom name I gave my satellite. Very frustrating.
- esassamanOct 06, 2018Tutor
Confirmed, all names look correct for all 5g adn 2.4g connections to both base router and sattelite, both in web interface and mobile app (iOs).
