steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Cmax04
Oct 06, 2018Aspirant
Same here.
esassaman wrote:
For those of you completely scared out of your wits as I was after reading all the previous posts, sometimes it just works.
I did the update just now. It was surprisingly fast, only took a few minutes. It took a few additional minutes for the sattelite to reconnect (wired backhaul). All settings are exactly the same as before the update. All attached devices are there with the same names. Sattelite is good, got a solid ethernet connection. No resets, no reboots, nothing needed. Whew.
Ryan1919
Oct 06, 2018Tutor
Can you confirm that your 5g connected devices to a satellite are showing their connection type in the web interface and app. For example all my devices that are connected to 5g say unknown for the connection type in the web interface and mobile app.
- BodiniOct 06, 2018Aspirant
Confirmed - RBR50 / RBS50 - Both devices show correct information for 2.4G and 5G. Wired backhaul and upgrade completed with no issues.
- Ryan1919Oct 06, 2018TutorOk thanks!! I think the main difference between our setups is yours is wired backhual. My 5g connections show as unknown and it will just say Orbi Satellite instead of the custom name I gave my satellite. Very frustrating.
- RedBatman89Oct 06, 2018Guide
Ryan1919 wrote:
Ok thanks!! I think the main difference between our setups is yours is wired backhual. My 5g connections show as unknown and it will just say Orbi Satellite instead of the custom name I gave my satellite. Very frustrating.Yeah mine are the same too, unknown which ticks me off a little, Hopefully Netgear is listening
- BodiniOct 07, 2018Aspirant
This RBR50/RBS50 operates in AP mode using wired backhaul and sits behind a pfsense router. DHCP, DNS, and NTP are provided by the pfsense router. I upgraded this via the IOS app and never ran into any of the issues others are having. I can't say which was upgraded first as I just let the app do the upgrade. Around 5 minutes later, everything was working again the were running the new firmware. The only other setting I've changed, besides AP mode, is to disable 'Daisy-Chain' under Advanced-tab -> Advanced Setup -> Wireless Settings -> Enable Daisy-Chain Topology. The wired backhaul wouldn't work correctly until this was done. Both the satalite and the router have retained the name I gave them which also matches the DNS provided by the pfsense router.
- esassamanOct 06, 2018Tutor
Confirmed, all names look correct for all 5g adn 2.4g connections to both base router and sattelite, both in web interface and mobile app (iOs).
