steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Oct 03, 2018Guru - Experienced User
Let us know if you experience any issues after updating FW.
Let us know if you apply the new FW and continue or if you factory reset the system and set up from scratch. Hopefully you can just update and continue, however if you seem to experience issue. Please try a factory reset if needed.
Hawkmoth
Oct 07, 2018Star
I need t reset to factory conditions and start over from scratch to get devices to switch to the satellite and also to stop showing the connection type as Unknown if they did show up on the statellite. All seems well now, though.
