steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Ryan1919
Oct 07, 2018Tutor
I just enabled dasiy chain and everything is working correctly now..My devices are switching between satellites and the 5g devices are being reported correctly in the web interface and mobile app..Before the update I had daisy chain disabled and everthing worked fine, but now i have to enable it for everything to work as expected..
Oct 07, 2018Guru - Experienced User
Hmmm 2nd user reporting differnent behaviros with Daisy Chain
- Ryan1919Oct 08, 2018Tutor
Just to clarify my system is not using daisy chain topography but after I checked the box to enable it every thing started working again. Each satellite is connected to the router
- FURRYe38Oct 08, 2018Guru - Experienced User
Seems like maybe something got reversed for Daisy Chain in this version of FW. Great. :smileyfrustrated:
Hopefully someone at NG can look into this
- JoeCymruOct 08, 2018Virtuoso
As posted in the other thread: Regarding the daisy chain issue after the inital download: I downloaded the update again from the Netgear site and reinstalled manually due to poor backhaul when daisy chain is off. This changed nothing. However with daisy chain on, the system is selecting star connection (hub and spokes). For my set up, the daisy chain on puts the system into a "select best" mode. With daisy chain off the system seems not to really know which way to go. Before the update, daisy chain on gave poor backhaul. Now it seems to only work well when on, and then the system selects a star pattern as the best connection.
It's a feature?
OOps. Dup.
- Ryan1919Oct 08, 2018TutorSame thing happens for me. With daisy chain off the system doesn’t know what to do. With daisy chain on the system selects star topography and everything works as expected. Before the update I could select daisy chain on or off and it would work as expected.
