steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Crestviewdoc
Oct 08, 2018Tutor
I have been following this thread and was dreading the update. My system is a simple setup of a router on level 1 of the house and a satellite on level 2.
I was updated automatically on Saturday and was unable to connect to the internet after the update. I then powered off the router and satellite. I rebooted the satellite and when I was able to connect to the internet a few minutes later I then plugged in the satellite. Since then the system is perfect. I have both 2.4 and 5g connected with approximately 9 evices connected, 8 wireless and 1 wired printer connected directly to the router. Everything is working flawlessly.
Under the old firmware I was disconected randomly from the internet, especially (as I work from home) when I was connected to my firm's VPN. Note that these disconnects never happended while connecting to a non-orbi router system. It was definitely an Orbi problem as has been documented by manhy other users.
Today is the first day back at work and after 2 hours I have (Thank G-d) not experienced any disconnects. I will report back after the work day concludes with an update.
Oct 08, 2018Guru - Experienced User
Do you have Daisy chain enabled or disabled with in your UI?
Glad yours is working.
Enjoy. :smileywink:
- CrestviewdocOct 08, 2018Tutor
Daisy chain is enabled on my system. (I have no idea what this means but it is checked).
Sorry...I forgot to indicate that this was in response to a request.
Enjoy.
Daisy chain is enabled.
My Setup (Cable 900Mb/50Mb)CM1000r>XR450> > EX7700 (Wireless Extender)
Additional NG HW: Orbi CBK40(Gateway Mode), R7800, EX7500/EX7700 and WNHDE111Message 162 of 168
