steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
SeaMonkey80
Oct 08, 2018Apprentice
I am curious to know, for all of you having issues with the Daisy Chain option being on/off, are you connected via Wired or Wireless Backhaul?
For the Wired Backhaul users, are you seeing issues with this setting? I am running on Wired Backhaul and have Daisy Chain set to off, with no issues. Only problem I am seeing is that the web GUI is not recognizing devices being connected to the Satellite, and instead reports them as being wired to the main Orbi unit. My iPhone is definitely not wired to the main Orbi. :smileytongue:
Ryan1919
Oct 08, 2018Tutor
Mine is wireless backhaul and I have to enable daisy chain for everything to work as expected. If I disable it nothing will hardly ever connect to a satellite and if they do it will show as a unknown connection type..
- FURRYe38Oct 08, 2018Guru - Experienced User
- Ryan1919Oct 08, 2018Tutor
Also I forgot to mention that if daisy chain is turned off then it will just say "orbi satellite" for the connected orbi instead of the name I gave it. Turn daisy chain back on and it will display the name I gave it for the connected orbi.
