steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Ryan1919
Oct 08, 2018Tutor
Mine is wireless backhaul and I have to enable daisy chain for everything to work as expected. If I disable it nothing will hardly ever connect to a satellite and if they do it will show as a unknown connection type..
Oct 08, 2018Guru - Experienced User
- Ryan1919Oct 08, 2018Tutor
Also I forgot to mention that if daisy chain is turned off then it will just say "orbi satellite" for the connected orbi instead of the name I gave it. Turn daisy chain back on and it will display the name I gave it for the connected orbi.
