steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
tdroz73
Oct 06, 2018Tutor
This update is hell. The previous version was nice and stable - why are we defaulted to auto-update?
Mine auto-updated in the middle of the night - woke up to intermittent internet. Rebooted the router and it came back up - at 1/10th the normal speeds! I have a gigabit connection and was getting 100mbps on WIRED connections - 40-60mpbs on Wifi.
I powered down the satelite and then restarted the router and rebooted the cable modem. And waited what seemed like 5+ minutes. Router now gives me gigabit speeds and regular wifi speeds 400-600mbps.
Haven't turned on the satelite yet...
I'm about ready to look for an alternative product. I will no longer recommend this product to anyone who asks.
No factory reset because that's total BS. I think that is purely coincidental that it corrects anything - likely because there's old settings in the config that don't get properly migrated during the update process. When you go through this process and factory reset - all you're doing is hiding bugs from Netgear. Make them find them and fix them!
Netgear - stop pushing beta software like this out. I understand its a complex beast - but doing a factory reset to install clean software means you have **bleep**ty software engineering practices. You can't both expect us to accept auto-updates AND require us to manually intervene for 30 minutes to factory reset or power refresh everything.
