steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
jweise
Oct 08, 2018Apprentice
My moden is a Arris SB6183. Desktop was connected directly to the RBR50 via ethernet cable and not using either Sats at the time.
Previous to this update (including Beta's) I had loss of internet problems, but not IP problem.
Oct 09, 2018Guru - Experienced User
Was the modem powered off while doing a factory reset and setup from scratch, walking thru the set up wizard? I would try this.
Also If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
So try this out as well.
- JoeCymruOct 09, 2018Virtuoso
A bit more on the daisy chain issue. It is not exactly a reverse order experience. With daisy chain OFF, I get poor backhaul but the connetions are not in a daisy chain topology, but in the star topology (hub and spolke). With daisy chain ON, I get good backhaul but the system is also operating (it says) in the star topology.
With daisy chain off, satelites keep dropping in and out ... you can watch the graphed signal strength like an animated whack-a-mole. With daisy chain on (but still in star topology) the satelites stay relatively steady in signal strength. Also strange is when I resync the satelites with daisy chain off, the system initially shows backhaul is good for a few minutes, but then shifts to poor.
5GHz backhaul is at Ch 157 in both cases on my setup.
I am also getting the irritating icon flash on Attached Devices exactly every three seconds. which was not present before the update.
- FURRYe38Oct 09, 2018Guru - Experienced User
Thanks for posting more information. This is something NG support can use to pass on to engineering to look into.
- RedBatman89Oct 09, 2018Guide
Well I'll be, I enabled daisy chain and behold my devices are correctly showing which ones they are connected too. What an odd update. I still have the issue of the sattelites going magenta before going blue upon reboot but this time I think it was faster. Well lets see how my rbk23 will be today.
Good to hear. Ya, NG is looking into the behavior. I believe PINK will be seen before BLUE. As long as your getting BLUE then OFF, you should be good. Let it run for a while and see how it does.
- Ryan1919Oct 09, 2018Tutor
I would just like to say that I'm thinking the same thing. My system stays in star topography even when daisy chain is enabled. I don't think it's reversed, but there is some kind of bug when it's disabled. If I have daisy chain disabled I still get good backhaul connection with my satellites, but my devices will never switch to the satellites when sitting right next to them, or least it shows in the admin section that there not connected. Also it will show unknown for the connection type for anything that is connected to a satellite on the 5g band and it will say connected to "Orbi Satellite" instead of the custom name I gave the satellite for 5g connected devices. Anything connected to the satellite on the 2.4g band will report correctly. Something else I noticed is that a link rate is displayed in the mobile app for devices connected to a satellite, but before the update the link rate would only show for devices connected to the router and not the satellite.
So long story short is that everything on my systems works as expected when daisy chain is enabled even though my system is star topography. If I disable it I still get good backhaul connection, but my devices will never switch between router and satellite and if they do they will be reported as "unknown" in the admin section for connection type and show that they are connected to "Orbi Satellite" instead of my custom name I gave the satellite. You also mentioned that the screen flashes for attached devices every 3 seconds in the admin page, but mine was doing that even before the update.
