steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
FuzzyJohn
Oct 09, 2018Tutor
Cable Modem: Arris SB6183.
Orbi: RBK50 (router + 1 satellite).
I did a manual update of the satellite first. While the satellite was updated the router decided to auto-update. The router was connected to the cable modem at the time of the auto-update.
Several days after the update to v2.2.1.210:
- iPhone connected to the satellite shows connection type as "unknown".
- Problems with the logs:
* I have the email logs set to Daily. The logs are emailed but do not seem to clear after that as they did in the past. Next day the email will include the previous logs as well.
* Intrusion attems do not appear to be logged. Only Login, DHCP, Access Control, Email Sent and so on events are logged. No DoS Attacks. - As mentioned, I only have one satellite. My Daisy-Chain Topology is enabled and I do not seem to have connection problems.
Other than the above everything else seems to be normal so far.
- FURRYe38Oct 09, 2018Guru - Experienced User
Good to hear. Glad it's working. Thanks for posting your information. You might try a manual update on the router portion, factory reset then setup from scratch and see if the highlights you mention still appear.
