steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
xanderwong
Oct 04, 2018Tutor
I have 16 different devices connected to Orbi, and if everytime the useless Netgear team decides to release a new firmware (which I cannot opt out or disable auto-update) and screws with my work, I am at their mercy. I am sick of this **bleep** every single time Netgear releases a firmware and things will go haywire.
With that aside, I really appreciate your advise FURRYe38, but I cannot even access the satelite (sorry not router) now through the ethernet cable. I am experienced in manually updating and doing the entire firmware update cycle, but this time, the satelite seems to be dead/bricked. Any advise?
MetaFuz
Oct 09, 2018Aspirant
To disable firmware autoupdates, try this. I'm holding at V2.1.1.16. I check the forums every few months or so to check the pain level for an upgrade.
https://www.reddit.com/r/orbi/comments/8ke43v/how_to_disable_autoupdate/
- FURRYe38Oct 09, 2018Guru - Experienced User
Other have mentioned doing a manual install and factory reset works for them:
