steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
Oct 10, 2018Guru - Experienced User
Try a factory reset and setup from scratch. If this fails, download the FW files to a wired PC and install them on the satellites first then the router, reset and setup from scratch.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
milk242 wrote:
My router updated last night and now my iPhone won't connect, when I try to connect to websites I get a certificate error that is pointing to routerlogin.net. It only affects my iPhone from what I can tell. No other devices, not my Apple TV's or cameras or TVs or computers.
I've turned off daisy chain and I would rather not hard reset the router.
Any fix for this BS issue?
milk242
Oct 10, 2018Tutor
Looks like the Orbi firmware screwed up the access control stuff. I had to turn it off to get my phone to work even though it said allowed.
My satellites used to all have Good connections, now one is Poor (RBW30). Coincidentally, it is the only one that didn't upgrade to this latest firmware.
Does Netgear even test?
- FURRYe38Oct 10, 2018Guru - Experienced User
Try a factory reset and set up from scratch the set up Access Controls again from scratch...
