steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
RedBatman89
Oct 10, 2018Guide
So any news orbi is going to fix this or can we be given an option to downgrade without the worry of an auto update?
Oct 10, 2018Guru - Experienced User
NG doestn' give any time frames on when FW updates are forth coming. You can try the down grade...
- RedBatman89Oct 10, 2018Guide
Issue with that is that it will auto update back to 2.2.1.210
- FURRYe38Oct 10, 2018Guru - Experienced User
Probably...
Discovered new bug, apparently even when you have the diasy chain enabled you can still get it asa 2.4ghz or 5ghz connection but it will just say connected to orbi sattelite since when I enabled free roaming it starting doing that but however even with it disabled it can still happen. I just power cycled my modem and orbi system and it still happened.
Also Daisychain doesn't full go off since the sattelities will still connect to each. I had to turn of and on Daisychain three times before the sattelities just connected to the router.
I'm exausted now. The Gui just loves to mess with you in this firmware. Also someone already said it but Apple devices come up as unkown. I wish I didn't activate free roam.
- FURRYe38Oct 11, 2018Guru - Experienced User
I know you must have been tired when you wrote this, however you may want to clairify and clean up this information. Kind of hard to fully understand what your trying to say...Will help those that will review this understand as well.
