steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
ekhalil
Oct 16, 2018Master
TayNinh wrote:
Hope someone can help me out.
I've been having wifi issue keeps dropping out on my iPad Pro 9.7" version with this router since the very beginning. I've updated my firmware everytime(currently on this fw version) there's a new one but the issue still exists. It only happens on that iPad and not on all other iPads/iPhones/PCs. It's very annoying that it drops wifi every 5-10 minutes. I reinstalled iOS and did all reset on iPad. I've read few others having the same issue but I can't find a solution. Is this a NG issue or Apple?
I had many similar issues.
Do you have any wired devices to the Router/Satellites? Any wired Mesh Speakers (Sonos, LG Music Flow or similar)?
All my wifi dropping/disconnections issues were gone when I disconnected those wired speakers.
TayNinh
Oct 16, 2018Aspirant
I have a couple of Sonos and HomePod, but they're wireless.
For wired connections I have a couple PCs, Smartthings, Hue Bridge, Printer, ObiTalk, few cameras.
- ekhalilOct 16, 2018Master
Do you see any of the symptoms below:
- Frequent DHCP messages related to your iPad in question (only If you are in Router Mode)?
- The iPad shows as Wired in the Attched Devices page?
- CPU load is higher than normal in debug.htm?
If yes then try to find out which wired devices are causing loops in your system.
