steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
LycanChief
Nov 04, 2018Star
After this upgrade, my download speed of any device connected using ethernet has drop. I am a 1G AT&T user and now if I am connected behind the AT&T router, everything is around 930Mbps download speed. If I go behind the Orbi, average is around 540Mbps. Something changes in this upgrade.... Any idea of what can be happening.
AT&T Router is in Passthrough mode!
Did a Factory Reset, this fix the Wi-Fi issues after the upgrade and the internet issue that had to refresh ISP lease to get everything working...?
This firmware has affected the unit and I really disappointed in NetGear Support... if you push a upgrade, must be tested, right now getting have of my internet speed and all the issues and problem after the upgrade... phone support must be 1yr.
- LycanChiefNov 04, 2018Star
Downgrade to 2.1.4.16 and speed is back where it need to be!
- phobosbsdNov 04, 2018Aspirant
how do you manage to downgrade ? Mine auto update to the latest firmware automatically after downgrading.
Because all the issues, I did a Factory Reset... Downgrade the Router first...after that the satellite... if you do the satellite first, it will upgrade to the same version of the router if it is at the latest version...
Good luck
