steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
phobosbsd
Nov 04, 2018Aspirant
how do you manage to downgrade ? Mine auto update to the latest firmware automatically after downgrading.
LycanChief
Nov 06, 2018Star
Here is how to diable AutoUpgrade:
To stop the Orbi from installing the updated firmware automatically follow the steps below.
Perform these step after you downgraded the firmware to a prior release.
1) Launch your favorite web browser and go to <Router IP Address>/debug.htm
2) Login <username> <password> when prompted
3) Check Enable Telnet
4) Start a Telnet session. I use Putty. Enter the <Router IP Address> Telnet is using port 23
5) You can skip this step if you like. I am calling it out for illustration purposes only...
Type nvram show | grep auto_* <ENTER>
You will see a list similar to this:
root@RBR50:/# nvram show | grep auto_
vpn_access_mode=auto
wl_auto_antenna=1
set_auto_agreement=0
orbi_auto_upgrade=1
ipv6_autoConfig_dns_assign=0
ipv6_autoConfig_dns1=
ipv6_autoConfig_dns2=
upnp_enable_autoScan=0
ipv6_auto_dns_assign=0
bas_auto_conn_flag=0
orbi_auto_upg=0
autofw_port0=
ipv6_auto_dns1=
ipv6_auto_dns2=
qos_auto_bandwidth=0
green_enable_autorefresh_status=0
enable_dev_auto_refresh=1
wl_rate=auto
auto_check_for_upgrade=1
auto_update=1
root@RBR50:/# root@RBR50:/#
The 3 configurations highlighted above you will want to update the value from =1 to =0
orbi_auto_upgrade=1
auto_update=1
6) To update run the following commands:
nvram set orbi_auto_upgrade=0 <ENTER> (no spaces after set)
nvram set auto_check_for_upgrade=0 <ENTER> (no spaces after set)
nvram set auto_update=0 <ENTER> (no spaces after set)
7) Type the following commands to confirm the 3 configurations are set to =0
nvram show | grep orbi_auto_upgrade <ENTER>
nvram show | grep auto_check_for_upgrade <ENTER>
nvram show | grep auto_update <ENTER>
8) After you confirmed the 3 configuration values are set to =0 then type nvram commit <ENTER> (this step will save the changes)
9) Type exit to terminate the telnet session
10) Go back to the <Router IP Address>/debug.htm web page and uncheck Enable Telnet
Please note within a day or so the Orbi will know there is an updated firmware release available but it will not automatically install it. If you do go back into a Telnet session after the Orbi knows there is an updated firmware release the configuration orbi_auto_upgrade will have a value greater than 1. That is okay. Do not change the value back to =0- errdogLiveNov 25, 2018Aspirant
That doesn't work anymore, my router updated last night after I did that yesterday to downgrade back to 2.1.4.16
That doesn't work anymore, my router updated last night after I did that yesterday to downgrade back to 2.1.4.16. Now those settings are still set to 0 but everytime I load the older firmware it autoupdates to the latest within 1 minute.
- DavenleiNov 25, 2018Guide
So after confirming all my settings in the telnet session for the Orbi were correctly set to 0, I also set the additional setting "orbi_auto_upg" to 0. So far the older firmware 2.1.4.16 seems to be sticking and not upgrading to 2.2.1.210 which is great.
I also set the Orbi to block the site "downloads.netgear.com" in the advanced>security>block stes tab to try to stop it from being able to access the update URL.
We are 24 hours in with the router not upgrading so I have my fingers crossed it will not update anymore.
- MikeB07Nov 30, 2018Initiate
I would change the settings in the router with telnet and it would update within minutes of powering back up. I tried rolling the satellite back first then rolled back the router and it has not updated, so fingers crossed as it has now been several days.
- RickDiasNov 30, 2018Tutor
Rolled back to 2.1.4.16 on RBR40 router, used telnet to change the nvram settings, rolled back the RBS40 satellite, Orbi is staying at 2.1.4.16 and will keep displaying "a new firmware upgrade is available" for the rest of eternity for all I care. Speeds are back up (getting 180 mbps on my comcast 150 service), satellite is connected via ethernet backhaul, all security cameras are stable again, I'm not seeing Comcast servers in New Jersey on my Attached Devices screen, even the Orbi app is behaving better - no more having to reload its devices screen to actually see anything. Finally back to what I paid for.
TLDR - abandon all hope ye who update firmware early.
