steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
shok9
Nov 06, 2018Aspirant
I have had this triband router and two satellites for 2 years but in the last few weeks it keeps dropping wifi connection to all my devices. Everytime I reset the router wifi comes back for some time and then it drops again.
- FURRYe38Nov 07, 2018Guru - Experienced User
What do you mean by reset? Power cycle OFF then back on or factory reset and setup from scratch?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
