steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
czar4you
Nov 10, 2018Aspirant
Configuration:
(ISP) ROGERS 1GB -> (ROUTER/MODEM) CODA-4582U 2a -> ORBI
Problem: Unable to get stable 600mbit+ connection via CAT6e network cable when connected to ORBI. If connected directly to CODA-4582U 2a, then I get stable 950mbit+ speed is achieved.
For testing i have utilized fast.com & speedtest.net
Things attempted when troubleshooting:
1) Upgraded to latest firmware V2.2.1.210 and performed factory reset. (NO DIFFERENCE)
2) Downgraded firmware to V2.1.2.18 and factory reset (No difference)
3) Modified CODA-4582U 2a settings from bridge mode to router, and Orbi as Access point. (with this method i wanted to minimize the load on orbi with firewall, dhcp and other items disabled) (NO DIFFERENCE)
4) Disabled IPV6 on CODA-4582U 2a (NO DIFFERENCE)
5) Introduced cisco switch in between CODA-4582U 2a and orbi (NO DIFFERENCE) 6) QoS page seems broken/not designed for newer version of bootstrap/css/html. I attempted to delete all, /QOS_rule.htm, enable/disable via http://orbilogin.com/QOS_main.htm (NO DIFFERENCE)
