steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
mdirrim
Jan 02, 2019Aspirant
The ISP gateway is ATT BGW210-700.
My house is about 2500 sq ft but I am doing this with the satellite and router in the same room.
On the previous release it had worked fine with both satellites far away from the router.
I believe that the router and satellites are all on .210 based on what is reported in the admin page.
However, since I am not getting a sync I don't see a way to verify this.
When I followed the reset instructions, I assume that the 'amber' light you are referring to is the one next to the power button not the light on the top of the satellite. When I follow the sync instructions I do not see the Pink light on the top - I just see the light on the top of the satellite go from a solid which to a pulsating white and eventually to magenta, it does not go to Pink.
I am doing this with only one satellite with the other powered off.
Kalotay
Jan 02, 2019Tutor
Surely, Netgear monitors this community and is aware of our issues. It is amazing that they chose not to jump in with a clarifying explanation or suggestions. This is NOT the kind of support customers expect. The community has only one choice: abandon ORBI. That is what I did. My new xfinity wifi works well enough. So long Netgear. You suck!
