steve8411
Oct 03, 2018Apprentice
Firmware 2.2.1.210 released as of 10/3/18
New firmware is available via the GUI ....
Let's hope for success.
madhatter
Jan 22, 2019Apprentice
is it possible that you are just losing DNS and your reset is reconnecting the DNS? I've had this problem on every Netgear router I have owned for the last 10 years. Try using 8.8.8.8 as your primary DNS and see if the problem gets better.
Loungepuppy
Jan 22, 2019Aspirant
That's a great idea. Something very simple to try. (This is my first Netgear router but normally I use 8.8.8.8 for DNS, just forgot to do it when I got the router i november. I'll do that and see if it solves the problem before I change the lease time.
(although I was looking forward to using Telnet for the first time)
I am a novice in many of these issues but come to think of it, maybe some apps don't lose connection? (eg Netflix, uTorren that can manage without DNS while they have a "stream"). I should check that too.
Thx madhatter
- ekhalilJan 22, 2019Master
Thx madhatter
Yes, please try the DNS change as suggested by madhatter, sounds like a good approach.
If not then let's try the lease time change as follows:
root@RBR50:/# config get wan_lease
Should give you --> 86400 which means 24 hours
root@RBR50:/# config set wan_lease=7200
7200 means 2 hours
root@RBR50:/# config commit
I don't think that you need a reboot to make the changes take effect.
With this you will force Orbi to ask to renew the DHCP lease from the ISP router every 2 hours.
- madhatterJan 24, 2019Apprentice
any luck??
- ekhalilJan 24, 2019Master
Loungepuppy How are things going? Any good news? :)
- LoungepuppyJan 24, 2019Aspirant
So far, so good. I should report back in a few more days to be sure. I work quite a lot so it's a bit difficult to be sure of the frequency of dropped connection before changing the DNS but I feel it used to be 2-5 times/day that either me or my kids noticed.
Also, if this works, next step is to turn on Circle again, since I disabled it the same day.
Will report back to make sure that this might be something others can try in case of lost internetconnection (well, DNS it seems) in the router.
Thx again guys!
- LoungepuppyApr 02, 2019Aspirant
A bit late but. Circle was the culprit. I am keeping it turned off now which is a bit sad since the Circle functions made dealing with my kids surfing/gaming a lot easier.
