cgfsd
Jun 18, 2019Aspirant
Firmware 2.3.1.60 Disabled Ethernet Connected Devices
I recently upgraded to v2.3.1.60 on my Orbi RBR50 and I lost all of my Ethernet connected devices. All connections show green and show activity, but the Orbi does not show anything is connected to E...
CrimpOn
Jun 18, 2019Guru - Experienced User
cgfsd wrote:I recently upgraded to v2.3.1.60 on my Orbi RBR50 and I lost all of my Ethernet connected devices.
All connections show green and show activity, but the Orbi does not show anything is connected to Ethernet.
To clarify: "show green and show activity" refers to (a) the Orbi web interface or (b) the Orbi "app"?
Do the wired devices function, and the question is why they do not show as connected, or do they actually not function?
cgfsd
Activity with the green blinking lights on the ethernet connection itself. All devices are working, the only change is the firmware.
- CrimpOnJun 18, 2019Guru - Experienced User
cgfsd wrote:Activity with the green blinking lights on the ethernet connection itself. All devices are working, the only change is the firmware.
What happens when one of the devices is powered off and back on? Does the device report getting an IP address from the Orbi after restart?
- cgfsdJun 18, 2019Aspirant
When I reboot a device it says no internet connection and does not get an IP address from the Orbi.
cgfsd wrote:When I reboot a device it says no internet connection and does not get an IP address from the Orbi.
And the WiFi connected devices are "just fine"?
Darn. I wish the Orbi ethernet ports had activity LED's like switches and PC's do.
Sometimes, the Orbi just loses it's mind and the only thing left is to do a "factory reset". This sucks big time if there are a lot of devices which have IP addresses assigned in the Advanced LAN Setup.
