rjantigua
Jul 12, 2019Guide
Firmware 2.3.5.30 valid for RBR50/RBS50?
I see in another thread that people are upgrading their RBR50 routers to 2.3.5.30 with success. I got the prompt on the Orbi app that this version was available for upgrade and I pushed the button t...
- Jul 16, 2019
Hi rjantigua
Were you able to update the firmware to 2.3.5.30? Firmware is already posted on our support site https://kb.netgear.com/000061080/RBR50-RBS50-Firmware-Version-2-3-5-30
Blanca
Community Team
rjantigua
Jul 20, 2019Guide
I successfully downgraded from 2.3.5.30 to 2.3.1.60 with no issues. I noticed both of the issues you mentioned: the 2.4GHz dropping on one of my satellites when I go to that interface. The long sync I'm attributing to a (now) standard sync process.
Geoff_C
Jul 21, 2019Aspirant
rjantigua wrote:I successfully downgraded from 2.3.5.30 to 2.3.1.60 with no issues. I noticed both of the issues you mentioned: the 2.4GHz dropping on one of my satellites when I go to that interface. The long sync I'm attributing to a (now) standard sync process.
I have also managed to successfully downgrade to v2.3.1.60 and stability seemed to have returned. As does the speed of sync. I think it will leave it alone now and let Netgear go back to the validation team with the big reject stamp for v2.3.50. Not sure how this got through quality control. Very pleased that firmware updates are now not automatic. Thanks for responding.
- FURRYe38Jul 21, 2019Guru - Experienced User
Did you two try a factory reset after loading v30 on your systems and setup from scratch to see if this helped any? I myself and others are working on v30 with out any problems...Just curious here.
- Geoff_CJul 21, 2019Aspirant
No ... I wanted to avoid a Factory Reset as I did not want to waste a huge amount of time setting up the system again. I use it just for WiFi distribution and did not want to have to start again.
As I said, I am delighted that the firmware downgrade appears to have fixed the issue and stability has improved.
I think I might now go back to "If it ain't broke, don't fix it mode" and leave firmware update alone unless something major goes wrong.
Try a manual FW file load by downloading the next FW update should you feel inclinded next time. A factory reset is recommended and it helps to ensure the FW is installed well and any mis-configurations will be cleared out.
Yes, if it works, don't fix it is a good method as well.
Enjoy.
Geoff_C wrote:No ... I wanted to avoid a Factory Reset as I did not want to waste a huge amount of time setting up the system again. I use it just for WiFi distribution and did not want to have to start again.
