SkywalkerPD
Sep 30, 2019Apprentice
Firmware 2.5.0.36 release notes
Hi, Just got a new firmware on my RBK50. version is 2.5.0.36. Are there any release notes for this firmware please?
- Sep 30, 2019The notes are now there, I upgraded and lost the "attached devices". Although all my devices connected succesfully after the upgrade only 7 devices showed on the list instead of the usual 20+ and 5 of them were not named correctly.
Reverted back to previous firmware and the list is now functioning correctly. First problem I've had with the firmware, so I've never factory reset or anything. If i get a chance i might try that later (or just stay on 2.3.5.30 !)
woodzy68
Sep 30, 2019Initiate
Sep 30, 2019Guru - Experienced User
Factory reset and setup from scratch the RBR and RBS to see if this helps resolve anything next time you update FW.
