-RCM-
Jun 21, 2020Aspirant
Firmware 2.5.1.16 RBR50 Trouble
Before upgrading to version 2.5.1.16 firmware, I was on 2.5.1.8. I had no issues with devices connecting. After I upgraded to 2.5.1.16, two devices would no longer connect. Even tried deleting and set...
Jun 21, 2020Guru - Experienced User
If it works great, I'd leave it until the next update. Don't fix what isn't broken.
Unless you really want the update. then I'd update the firmware, factory reset, and reinstall.
