CrimpOn
Jun 04, 2020Guru - Experienced User
Firmware 2.5.1.16
Noticed post today stating that new firmware was automatically installed and the Orbi immediately started having problems. Went to Advanced Tab, Administration, and "sure enough", my RBR50 says that...
Jun 26, 2020Guru - Experienced User
jijun1964 wrote:
I already reset my RBR50 and RBS50. Update RBS50 frimware to 2.5.1.16 and update firmware RBR50 to 2.5.1.16. Then restore all parameter and off/on router and connect to Internet. All done. Under monitoring wifi conection loss.
jijun1964
Jun 29, 2020Guide
I will set the router and wifi setiing follow your advise. At current update, wifi disconnected still occurred more frequent compare to 2.5.1.8 firmware.
- FURRYe38Jun 29, 2020Guru - Experienced User
So even with v2.5.1.8 you still saw disconnections?
- jijun1964Jun 30, 2020GuideI mean firm 2.5.1.16 more frequent. I days at least 4 to 5 time. If firmware 2.5.1.8 1 week about 7 time.
- FURRYe38Jun 30, 2020Guru - Experienced User
Well even if your seeing problems with FW regardless of version, seems that your system or your ISP service needs to be looked at.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem if your using cable ISP services.
