Haj
Feb 19, 2020Aspirant
Firmware 2.5.18 Slows Down
I updated the firmware to 2.5.1.8 on both the RBR50 and RBS50. The device map and naming functionality is nice. However, after 24 hours or so, the system slows down to about 40 Mbps on all wireless...
SeaMonkey80
Feb 19, 2020Apprentice
Haj wrote:I updated the firmware to 2.5.1.8 on both the RBR50 and RBS50. The device map and naming functionality is nice. However, after 24 hours or so, the system slows down to about 40 Mbps on all wireless devices (iOS, Mac and Win10 all tested). I have a gigabit connection with Verizon and the wired devices are not impacted by this reproducible slow down. A reboot or the RBR50 restores full speed on the wirless devices for another 24 hours or so, at which point the speed throttles back to 40Mbps.
I fell back to 2.3.5.30 and full wireless speeds are maintained.
I have experienced the same issue on 2.5.1.8. My system is setup with Ethernet Backhaul (AP Mode), and I am on Xfinity Gigabit. After a few days, the wireless speeds will drop (download drops from ~600 Mbps to ~150 Mbps; upload drops from ~40 Mbps to ~10 Mbps. Factory reset does nothing to remedy this situation, no settings have been changed (or need to be changed), and the wired clients do not see this same type of drop.
It is frustrating having to reboot the system to get these speeds back. Also, I was having this same issue on 2.3.5.30...although it would last longer before the speeds would drop. There is clearly a glitch in the firmware as my system has been rock solid before either of these two updates. Hopefully, NG gets their act together and fixes the problem.
Feb 19, 2020Guru - Experienced User
What devices are you using to wireless speed test?
Are wired speed with a LAN cable connected PC still good?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
