autigers1970
Aug 10, 2021Aspirant
Firmware 2.7.3.22, a poll
So I have an RBR40 with two RBS20 satellites and the 2.7.3.22 firmware just showed up in the app as an update. I’m currently on 2.6.2.104. I’ve seen some threads here with bricked main routers and ...
pdeethardt
Aug 16, 2021Apprentice
For what it's worth (knock on wood) my system has been running for a week now on 2.7.3.22 with no issues. I have an RBR50, RBS50, and RBS50Y. I upgraded each satellite manually, waited for them to fully reboot, then upgraded the router. I was a little worried because the last manual upgrade I did caused some issues on the router where the login web page would not load, but I was able to complete the update using the app. No issues at all with the upgrade process this time.
Aug 16, 2021Guru - Experienced User
Did you reboot these devices or power them OFF then back ON after the update or just continue to use the system as is?
- pdeethardtAug 16, 2021Apprentice
Just continued to use the system as-is. I haven't down the full power down with any of the updates I've applied so far, and I haven't noticed any issues.
FURRYe38 wrote:Did you reboot these devices or power them OFF then back ON after the update or just continue to use the system as is?
